drelldrell
- Joined
- Jan 27, 2015
- Messages
- 50
Hello all,
I bought a house in late 2013 with a two car garage (20x22) that is likely 30 years old, but in good structural condition. I live in Chicago, so the winters get very cold. Summers are moderately hot in July and August. My plan is to use the garage for some general woodworking/carpentry work and man cave type hanging out. There is no heating or insulation. I need advice on two things:
Slab - The slab is in rough shape with cracks, pitting, unevenness, and some water wicking up to surface in one small area (likely due to one of the cracks). I plan to have the slab replaced as soon as it warms up in Chicago. The contractor will cut out a 6" internal perimeter to leave the existing footings in place. No stem wall. The 3" on compacted gravel followed by a 4" slab. Should I add a vapor barrier and possibly foam board under the new slab? Also, I am thinking about digging down about 12" around the external perimeter and adding foam board for frost protection. Is this sensible to do?
Insulation - Given I would like to use the garage most of the year, I want to insulate to keep in heat when in use during winter and prevent excessive heat in summer. I likely will use a propane heater of some sort next winter. The wall has OSB already with no insulation. The hip style roof is uninsulated. Ther are soffit vents. I added foam board insulation to the inside of the garage door. Is blown in insulation a good idea for the walls? I guess I could rip out the OSB since its nailed in, add FB and a vapor barrier, and then add OSB or plywood, but that seems like more work than blown in. Is building a ceiling and blowing in insulation better that using baffles and batt insulation to insulate in the roof rafters?
Thanks for any and all advice.
