Reinforce the floor for 4 post lift?
rarebreed
Clover, SC.
So I am getting quotes to add a third bay to my existing garage and it's WAY more than I want to spend. So I am going back to my original plan to put in a high lift door kit with a jack shaft opener and a 4 post lift. I have heard from a few of the contractors stating that I will need to reinforce the floor for the 4 post lift so that the slab does not crack? The garage floor is a standard 4" slab. My question is if any of you have ever had issues with a lift cracking the floor or if you recommend a way to add in the extra concrete in the areas where the post's will sit on the floor.
Any advise is appreciated.
rsanter
visalia ca
Most 4 post lifts do not need the floor reinforced but check the manufacturer specs.
You could always put a 14"x14" by 3/8 thick steel plate under the legs to spread the load if it is an issue
Bob
rburke65
Canfield, Ohio
If your floor is in decent condition, you should have no problems with a 4 post lift on your concrete floor. At 4,000 psi, concrete can withstand a lot of weight. That's 144 times that in a given 12" by 12" area per each post! I think you will be fine. IMO.
Stuart in MN
Minneapolis
You shouldn't need any extra reinforcement for a four post lift, as mentioned above they spread their weight out over a larger area than a car.
malibu101
Walnutport PA
I ain't not no engineer. :tard:
But I look at it this way- The car sits on 4 tires and the post sits on 4 areas about the same size as a tire footprint.
Add the weight of the car and the weight of the lift and the total weight is probably about equal to a loaded pickup truck.
Would you park a loaded pickup on the concrete?
See what I'm getting at?;)
holdover
VA
the pads for a typical 4 post are 12 X 12 X 4 = 576 sq in. A typical tire contact patch area is let's say 7 X 8" X 4 = 224 sq in, even adding for the weight of the lift not a problem with even 3500 psi cement. The contractors you spoke to must be hungry...
Rookie2
Western Pa.
A friend installed one outside on asphault and it's fine. AND it is made to pick up and roll to another location.
R
rarebreed
Clover, SC.
That was my thinking as well. Also, have any of you installed a high lift door kit? I don't need to reinforce the header above the door when I move it up, right? same contractor says that I would need to do that and wanted $2500 to do all the work with the high lift kit. He's nuts if he thinks I am going to pay that much.
A high lift kit is all of about $350 plus a lift master jackshaft opener, right?
Dakota00
Woodbridge, Ontario
The header above the door doesn't get touched. A high lift conversion cost about $350 installed which includes extension tracks, new springs, bigger drums and cables.
