Hi Folks.I bought a car yesterday and the Rear Demister isn't working.
I have checked continuity at the rear window end from terminal to terminal - all ok.
The switch in the car does not light up when you press it - it's a kia Sorento 2010 and the switch is part of a cluster of controls.
My query is this:
I have checked the fuse and relay are OK - BUT when using a multimeter on volts, connecting the black wire on the multimeter to the negative battery terminal - I am getting a 12v reading on the relay socket at 30, 85 AND 86 !
I thought I would get 12v at 30 and 85 but not 86 as well ?
I also took the cover off the relay and attached the multimeter to the rear demister connectors and pushed the relay switch arm to make contact and got 12v at the demister connections.
It just seems off that I would get 12v power when touching pin holes 85 and 86.
Any help appreciated please.
Thanks
My query is this:
Thanks
