Reloading Room Floor
Cannongear
I'm in the planning stages of building a 10' X 12' Reloading room inside my existing 24 x 30 shop building.
Existing flooring is open concrete slab with various dirt, old paint, etc. stains.
I'll power was the floor ( And Let it dry thoroughly ) before I start the framing so that I have a clean surface to start with.
I'm planning on two work benches as well as space for a couple of shelving racks and a horizontal file cabinet that I have my dies, etc. stored in now.
Under the workbenches will get either cabinets or a couple of Roll-a-Way bottom tool boxes with the casters removed.
The floor area is only 120sqf so there's not going to be a lot of floor area exposed due to the work benches etc.
I'll have a couple of drafting type lab stools and the floor shouldn't have any heavy traffic or equipment, metal casters, jacks, or that type of wear & tear.
So - Now to the flooring:
Epoxy Coating or CVT ?
Mark_17
I'd just do racedeck for the ease factor. I'm also a fan of the look.
C
Cannongear
Racedeck has too many nooks & crannies for stuff to get lost in.
cvairwerks is right, primers and spilled powder, Detent balls, springs, C clips, E Clips, screws, pins, etc. all need to be found and retrieved / cleaned up easily.
Smooth is fast.
mike93lx
Richmond, VA
I'd look at commercial carpet squares. Dropped stuff will bounce and scatter less, plus make the floor a little more comfortable.
I used foam/rubber mats for mine
gleman
Michigan And Florida too!
Don't feel too bad.
I got talked out of the tobacco color for my basement shop and ended up with Thousand Island Dressing.
When I'm staring at the floor I hear this.
Here's my basement workshop floor.
I forgot which brand of epoxy I used but it's really durable. On a positive note about the floor, it's impossible to lose any small parts and it helped brighten the room with reflective light.
vwpieces
Hills, PA
I stand a lot while reloading, sizing, lubing cast. I just put a foam rubber 3ft wide runner, no holes, in front of bench. I'm in basement on concrete.
rjacobs
Dallas, TX
I put the lifeproof vinyl down in a room in my last house that I had setup as a reloading room.
Was pretty cheap and easy to put down.
I had an 2x8x3/4 rubber mat that I put down in front of the bench where I stood.
crewchief888
NW indiana
my reloading/gun room is in the basement of the house.
smooth concrete floor throughout, never been sealed or painted.
i have an outdoor kind of floormat in front of the bench for when im standing, i occasionally sit down on a bar stool as well. i have a 2nd bench at desk height for cleaning ect.
