Well with 12" of snow forecast I figure it's a good time to fix the blower/tractor I haven't run since last winter.
Summary: Gas tank is shot, cracked in a few places and leaking from the bottom. New tanks are NLA or more $ then worth (30 ye old Toro poorly maintained/beat previosly). Need options for remote gas tank.
Tried a few things to repair:
-gas safe permatex around the bung got me through last winter, cracked expanded over summer
- tried threading in a brass npt fitting. Planned to drill and tap, but a 3/8" fitting screwed into the hole. Leaked overnight. Not enough wall thickness to drill/tap for larger.
-gooped the above fitting up with gas safe epoxy and threaded it back in, have my doubts about trying it today.
Couple options I see for remote tank:
-5 gallon outboard motor tank. Will Kohler fuel pump pull up the pickup tube? Tank is about 8" deep, port is on top. I can mount this higher.
-3 gallon gas can with brass fitting installed in bottom. Plan is bushing from inside can, metal washer, gasket, can, gasket, washer, elbow to barb.
Any easy options I am missing?
