Removal on un-adhered chips
AWoodwell
Phoenix, AZ
Hello all,
Just curious what everyone would recommend for removal of un-adhered chips/flakes in between the epoxy and finish coats. In my mind, not all the flakes are going to stick, one would think that you'd want to remove those before top-coating. Thought about a simple broom, but don't like the idea of brushing a freshly dried coating. Also thought about a blower, and that seems to be what I've come up with as my best option.:monkey_po:
Thanks
AW
Shea
California
I like to use a metal edged squeegee to lightly scape the surface first. This helps to knock down any of the chip edges that may be sticking up enough to poke through the surface or create a bump in the top coat. I'll then use an electric leaf blower to to remove anything that is left after I have swept up the remainder.
tncatadjuster
Memphis, TN
+1:thumbup:
A
AWoodwell
Phoenix, AZ
If you install light, medium you will have little if any.
Use an electric blower not gas!!
I was planning on using an electric blower, but out of curiosity, why not gas?
Didn't really think of a squeegee + blower combo thanks! I'll probably go with that.
Jsf721
LI, NY
first top clear would be "messy" but the final top coat of clear would be perfect.
Well, I thought about that...but would you really want to top coat over a chip that's not bonded to the base coat? Sounds like a recipe for failure to me.
pauloman
the professional way to do an epoxy chip floor is to introduce the chips into a clear intermediate coat of wet clear epoxy or clear poly - backrolling the chips well into the wet coating.
sprinkling the chips into the pigmented base coat is the 'low end' approach.
Jsf721
LI, NY
Makes sense, I did not thinlk of that-Thanks
hofiveo
The unprofessional way.
dcs Inc
Indianapolis, Indiana
Looks great. I'd have to see it in person to warm up with that color combo but with the right wall colors I think it would be great. I've installed some pretty wierd colors but in the end the designer pulls it off.
hofiveo
Winthrop College, South Caroloina school colors, or close as they could find.
