Here's another picture of that old Darley portable fire pump I've been thinking/working/posting on:
My question at this point is in regard to going about removing the pump portion from the old model (23A) Briggs engine, so I might run/test the engine (for extended times and higher-end throttles) without the pump (pump with no water) attached. Think if I remove the four bolts holding this flange (or coupling whatever it might be called) where I'm pointing in the next picture, the pump portion would just pull/slide right off the engine shaft (once that small 3/8” copper line is disconnected too of course)?
Or, do I instead or maybe in addition need to remove the “pump body” from the flange where I'm pointing in the next picture:
And here's just another shot of the business from a different angle:
Just to remove the pump from the engine I suppose I'll very likely end up needing to remove the key from the shaft? Or just remove those four big bolts connecting the pump coupling to the engine housing and the whole pump business it all should just easily “slip right off” for me? Any comments appreciated.
