Remove Walker Turner chuck
FrankLee
seMI, 48317
Many bearings with the same OD and same width come in several sizes of bores. For example, 6202 bearings come in 15mm, 16mm, 1/2" and 5/8" bores. The "10" in 6202-10ZZ is really 10/16ths, aka 5/8ths.
I almost always use the "freeze/heat" technique to install bearings.
Bbp78
Philadelphia
Frank, thank you so much for all the help. That freeze/heat technique looks amazing, you are a wealth of knowledge. Thank you again, I will follow up in the next few days.
Bbp78
Philadelphia
Okay I got the bearings today and just compared them. The OD and thickness is the same, but the ID of the new one is slightly smaller. It’s .5865 vs. the original is .6200. Do you think it’s worth me hunting down the 6202-10ZZ? Maybe I’ll ask in the Facebook group you mentioned Frank. So close but so far away.
Cruzan80
Denver, CO
As it was stated before, "normal" 6202 bearings have a 15mm bore, and yours need the 5/8 bore. So it is different size.
Bbp78
Philadelphia
Update: the Walker Turner Facebook group pointed me to Jeff at the Walker Turner Serviced Machinery company who has been a huge help. They sell bearings and recommend Loctite 638 to install them, so that’s great news. They said the original bearings are obsolete, but they have had success with the bearings they sell. I’m waiting to get a quote on a belt/pulley guard from them as well. I’ll follow up once I get the bearings installed. Thanks and have a great weekend.
