The chuck key holes are enlarged.
Generally that style of mount uses a right-hand thread for the screw and left-hand threads for the chuck/spindle. Use your chuck key to hold the chuck while you unscrew the screw,. then chuck a large Allen key in the chuck and give it a couple of good whacks with a deadblow or soft-face mallet--in the direction that seems wrong. It'll usually spin off after a whack or two.The Chuck is mounted on a shaft with a screw at the inside top of the chuck; it is an Allen head cap screw. Thank you to all who replied to my question.
Good morning, I don’t mean to hijack this post, I’m in the same situation trying to remove the chuck from a Walker Turner 900 drill press. Joe Flinn, I hope you got yours off and don’t mind me jumping into this thread. I see Beerhippies recommendation above, does that mean that the chuck is threaded on or am I misunderstanding and you’re using the large Allen key as a way to apply force with the dead blow? I saw they make wedges for chuck removal, but I like the Allen key idea better. My chuck seems to be missing the threaded nut above the chuck, does that matter? Do I need to replace that? Thanks for any suggestions and guidance, it’s appreciated.
Here’s another picture. If I get this thing off, I need to figure out how to clean it and get it working better. I’m sure there are plenty of threads on how to do that.
Not really, unless you want to get a collar nut.I saw the threads are boogered up, is it necessary to fix those if I get the chuck off?
There are several factors. Probably one of the most important is the condition of the bit surfaces on the jaws. They should be smooth and straight. The condition of the taper socket is another.I will also get some wedges like you recommended FrankLee. How do I know if the chuck should be replaced or can just be cleaned and lubed?
Not at all. Everyone is/was a newbie at everything.Maybe that’s a silly question,
I guess if it doesn’t work well after cleaning then I will know. Can you tell I’m new to this, thanks again.
Threads can be made usable with a thread file. IIRC, that collar is threaded 1-1/16, 20 tpi.Hi all, I wanted to update you. I was able to pop the chuck off last night with wedges so that was a relief. I may have mashed the threads above a little bit. Is it possible to fix those or remove that piece?
I don't think so. The only time you'd need them is with an uncommon taper attachment; router bit collet, planer attachment, etc.I guess it doesn’t matter in the end?
Jacobs Service and Repair:It is a Jacob’s 6A with a 33 taper FrankLee, like you thought. I will look for disassembly instructions when I have some time. Thanks again for all of the help.
It really depends on your expectations.Do you think it makes sense to get a new chuck if it’s so worn?
There are many grades of quality and therefore a wide price range. Again, it depend on how much you are willing to spend.If so, is there a particular chuck to buy?
The threads, the pipe wrench marks, the impact marks, the striations on the taper... Were you able to check runout?Thank you both for your responses. I’m just a woodworker so won’t really be drilling metal very much. It appears Jacob’s still makes quality chucks, but they are not cheap. I have no problem paying for a new one if necessary since I’m putting all this work into it. I will try to get the chuck apart to inspect it further. FrankLee when you say the condition of the spindle, are you referring to the threads? Maybe I’ll try a thread file like you said before to see if I can make them better.
I use a Proto puller with a sleeve from a fubar chuck to dismantle and reassemble chucks.When you say you use a puller for the chuck, is that a bearing puller? Thanks again.
I believe you want the surface below the threads to be flat.Hi all, I wanted to update you. I was able to pop the chuck off last night with wedges so that was a relief. I may have mashed the threads above a little bit. Is it possible to fix those or remove that piece? I guess it doesn’t matter in the end? It is a Jacob’s 6A with a 33 taper FrankLee, like you thought. I will look for disassembly instructions when I have some time. Thanks again for all of the help.
FrankLee thank you, I haven’t checked runout yet or been able to do much lately. I tried cleaning some of the parts on Sunday and got them cleaned pretty well. Can I soak everything in mineral spirits to help dissolve the old grease? I cleaned them with Simple green and now have them soaking in WD40, hopefully that’s not a mistake. That puller looks awesome, is there a redneck way to do this, lol? I’m not sure I’ll be able to track a puller like that down.The threads, the pipe wrench marks, the impact marks, the striations on the taper... Were you able to check runout?
Wow Jonah what a great find, I see a few other WT drill presses by me, but not sure I want to start collecting for parts.I found a NOS Jacob’s chuck at a local distributor 15 years ago when I was rebuilding my WT900 and put that on it. It had some chinese junk chuck on it and I wanted it restored to original. I actually found a NOS set of quill bearings at the time as well.
Craftsman Drill Press
DP#151 - Part 8 I refurbished the chuck this morning. This is a Ridgid Supreme chuck, model 6T33C. It was a little sluggish opening and closing, so it definitely needed dismantling. This chuck is very similar to a Jacobs 633C, but the procedure to dismantle is very different. It took several...www.garagejournal.com
These Proto pullers are very versatile. I found all my pullers at estate sales and garage sales.
Dave, that’s something to think about if I can’t get the Jacob’s apart. Thanks
I'm not sure what you mean by everything, but I soak many parts in mineral spirits or lacquer thinner. I clean many other parts with Grez-Off without any further soaking.FrankLee thank you, I haven’t checked runout yet or been able to do much lately. I tried cleaning some of the parts on Sunday and got them cleaned pretty well. Can I soak everything in mineral spirits to help dissolve the old grease? I cleaned them with Simple green and now have them soaking in WD40, hopefully that’s not a mistake.
It is.That puller looks awesome,
Some dismantle chucks using a vise as a press. Check Jeff's Shop video. Jeff is member @11b30b4 here on GJ.is there a redneck way to do this, lol? I’m not sure I’ll be able to track a puller like that down.
I would not recommend mixing the original grease with a synthetic oil. Use 3-in-One 20 weight, or regular 3-in-One.If I don’t remove it, do I try to get some Super Lube Oil inside it or how would I lubricate it, I don’t think I could get grease in it.
Is the fit between the shaft and the bearing sloppy?I was able to get out in the shop tonight. The bearings are SKF I 70336 AZ. They are 35 mm OD, 15.75 mm shaft, 10.96 mm thick. I googled that and couldn’t locate much. I need to look more, the 10.75 mm shaft seems like it will be difficult to find. The bearings in the quill are pretty stiff, I wonder if I damaged something trying to pop them out the other day. They don’t look damaged though. This is a shame, what a beautiful machine to have such odd bearings. If I can’t locate new bearings, Frank I will try your method above. On the bearing I was able to get out for the other end of the quill, do you recommend something like Super Lube grease? Thanks again.
In general,If I can’t locate new bearings, Frank I will try your method above. On the bearing I was able to get out for the other end of the quill, do you recommend something like Super Lube grease?
