Removing 100% Silicone Caulking?
Chatam/Garage
So, what are the tricks of the trade for removing the clear 100% silicone caulking so I can re-do my shower door, which is mounted on a fiberglass shower stall? So far on-line I've read about mineral spirits, nail polish remover/acetone, and also clear PVC primer. I'm just curious what works well and won't harm my shiny white shower stall.
The Gambler
ohio
a razor blade scrape with a sharp blade... it also might pull right off once you start depending on how old it is
The Cobbler
I use a razor scraper to get the bulk of the silicone off, then I go over it with mineral spirits on a rag and scrape again with a good sharp blade . the mineral spirits softens the silicone. a bit of lacquer thinner after that to remove the residue from the mineral spirits . you end up with no visible traces of the old silicone .
If on fiberglass I would use mineral spirits first to soften the silicone . mineral spirits will actually bubble the silicone off if given enough time & spirits . Mineral spirits won't harm the finish on the fiberglass.
