I'm attempting to replace a 2004 civic lower control arm, the arm has the ball joint in knuckle on this model. I talked to the fellow techs at the shop I help at, one says to use a pry bar and hammer the arm to get the control arm out from the ball joint. The other tech tells me all you have to do is hammer the LCA and it will come out no problem. Can you guys chime in?
