mnev
Any tips?
I've gone through some Youtube, it's all overly intense.
Skipping ahead after weak failed attempts, I've strapped the tank to bench and tried pipe wrench with a cheater bar. No movement at all, and not much room to get the wrench on inside the protective ring.
I have a piece of 3-sided steel I may try to cut a notch in to fit over the valve, that I can get a better grip on above the ring with more leverage. Saw something like that on YouTube. This is a small BQ tank. There aren't any holes on the base ring to put a bar for added leverage, as in putting the valve in a vice and unscrewing the tank from the valve. BTW, I also have to buy a vice; I know, shame; last one stayed attached to the bench I left in TX when I moved.
But otherwise, any tips?
No cutting until the valve is off and tank is washed out.
Thanks,
Nev
Thanks,
Nev
