LifeLongWNYer
Last November, I purchased and installed a radiant, gas fired, wall heater, a small one, in a "terrace room" on my house. The goal was to keep it warm enough in there, so that I could keep some plants from freezing. The heater has worked well, and I am happy with it, and its' performance.
Well, spring hit WNY a couple of weeks ago, so I shut the unit down, thinking ( foolish me ) that I wouldn't need it again until the rapidly arriving fall. As luck would have it, we ran into a stretch of "cool" weather last week, and weekend, and I wanted to fire the unit back up. While doing so, it developed that the ignitor in the unit would not light the pilot light flame. I opened the ignitor and discovered that the AAA battery was dead, so no problem, I'll stick in a new battery. Then, while looking at the battery closely, I noticed that the negative end has that white corrosion which grows out of batteries when they are old. Next, while shining a light into the hole where the battery goes, I noticed that there is some corrosion at the bottom of the hole, on the terminal which mates with the negative terminal of the battery.
Now, this hole is slightly larger than the diameter of a AAA battery, and about the same depth, so I don't know how to get that corrosion out of there. The battery holder is recessed into the top of the heater, and there appears to be no way to get it out of the heater, without ( at least ) removing it from the wall, and taking it apart, something which I am not excited about.
So, my question is, how do I get that corrosion out of the battery holder, so it doesn't keep growing? This isn't like a flashlight, which I can just toss when it quits working.
Oh, yes, I did learn something from this. If I EVER buy anything again, which comes with a battery, THAT battery gets tossed in the trash, and I will install a brand new battery in the device, especially if the battery which was furnished contains only Chinese characters on the label. Also, to be safe, when I finally do turn this thing off for the summer, I'll pull the battery out until the next fall.
Thanks,
Thanks,
