promethean-in-fl
If it was broken off flush a machine shop might be a good choice. I recently watched a video (machine shop) where he demonstrated removing a flush bolt. He used a endmill to make the broken bolt flat then drilled the center of the bolt out. The drill bit was the same size as the root of the bolt thread. If done in the center of the broken bolt it will leave only the thread which can be fished out using a pick. He got the complete thread out in one piece, looked like a thread repair insert when out. The PO's situation, I would use vise grips first, then weld a nut if the VG didn't work.
Did they use a right hand or left hand drill bit?
