Removing cast iron in the floorboard....?
rshimizu12
San Diego
I am trying to remove the cast iron under the bath tub. Some of the cast iron protrudes up through the floor. I am thinking of heating the joint and see if tt comes apart. The other option would be to cut from the inside of the pipe with a die grinder or sawzall.
R
rshimizu12
San Diego
I may trying using chisel. The problem is that goes above the floorboard. I wonder if a rotary hammer might work....?
rustyzman
Chicagoland
If not saving the pipe and there is a bit of room to swing, I agree a sledge will do it quickly.
Removed all my all CI pipe from the very shallow crawlspace laying on my side with a 3lb straight pein. Few good whacks on the bell joint and it will crack right open. Wear a respirator, lots of dry rusty **** will come out.
Alternately, if trying to save some of it, sawzall from the outside or inside as you see fit. Respirator again, for dry rusty **** and lead. CI cuts easily with a good fine tooth blade. I would love to try one of those new carbide tipped ones on it, but alas it is pretty much all gone in my place now!
I am a great fan of PVC for sewer lines and replace old clay, iron or cast iron pipe whenever the need arises. It just isn't worth saving generally.
I suggest skipping the heat. Even a regular lead joint will take a ton of heat to get apart (fire hazard) and the Oakum will probably burn with a nasty stink. It is a different animal pouring molten lead into a joint than it is making molten lead inside an existing joint.
Innovate1
Snap soil pipe cutter. Cut a section out drill the lead out of the joints pick out the oakum.
Yep. If you want to take the joint apart take a drill to the lead in a number of spots and pry out whats left of the lead and oakum. If you want to cut below the joint I have used a carbide grit sawzall blade if I recall correctly. Haven't ever tried a snap cutter but apparently they work well. You can get rubber inserts that fit in the bell and convert to PVC. Do you have access below the floor?
gahrajmahal
Cincinnati, Ohio
A cast iron snap cutter works amazing! I rented one while remodeling my relatives kitchen. He is a philosophy professor and rarely laughs out loud, but he was giggling like a school girl when we were snapping that 4” cast iron pipe into sections for removal.
