Removing coolant hoses advice.
edcantu9
Southeastern Iowa
Hello all. I am changing a starter on an 2005 Mariner V6. I have to move some hoses out of the way.
I have never dealt with the cooling system but it will be my first time.
Is it easy as just removing the clamp and taking out the hose?
I always envision the worst case scenario when dealing with new things. I see lots of pressure and it squirting out!
Of course the car has been cooled down, I know that much! LOL
Garett
BC Canada
You shouldn't have any issues. Usually so it's less of a mess, drain the coolant level down below the level of the hose first. Then when you're done, put the coolant back in and bleed the air out.
Kaizen
New England
a couple of tips. no it won't just pull off. take a pair of needle nose pliers or such and try and push the hose off by prying between it and the fitting its on. second thing to then try is get a flat blade little screwdriver and get it in there between the hose and the fitting. carefully move it around unsticking it till you get it off. don't overdue either of these by breaking anything or scratching the fittings.
no pressure just antifreeze.
if your water pump has a metal pipe coming out of it that goes to a hose careful you might have to reuse it.
use a 3m stripping disc to lightly clean the mating surface. should be perfect before putting back together.
buy two gaskets in case you have to do the job twice. ***** cause you don't know its good till you put it all back together. make sure you let the gasket material or rtv dry before testing.
consider getting new hoses while you are in there.
Bondo
Greenfield, Maine
Ayuh,..... Invest in a Hose Pick, 'n it becomes a simple matter,....
Slip it in between the hose, 'n fittin', wiggle it around, 'n the hose slips off,....
They make a special hose removal tool. It looks like a heavy duty pick but the end is bent back 180°. You slip the end under hose and pull.
Rlfd213
Jose the hose pick of a pair of channel locks to break the hose free. Make sure the coolant is drained and if you have gone that far you may as well out new coolant in and change the hoses and clamps too.
T_R
Maine
Why are you taking hoses off?
On those just take off the air filter and the shifter cable. The starter will come right out then.
jerseykat1
Central New Jersey
If the owner of that mariner is family. Tell them to sell the truck. They are money pits. Speaking from experience as a auto technician.
Sent from my Nexus 6P using Tapatalk
pmiranda
Austin, TX
If you are going to pull the coolant hoses, have a nice big clean catch pan ready to capture all of that. Maybe I'm ghetto but I always reuse it unless it looks dirty or rusty. Mine usually looks pretty clean and I filter it through a new shop rag in the bottom of a big funnel just in case anything gritty or metallic (or bugs) gets in it.
cpttuna
napoleon ohio
If I remove a hose, I'm usually replacing it so I use a cutter knife and slice it. It comes off easy then.
Lotek
Los Angeles, Ca.
Yeah, that's ghetto, coolant is cheap, the additive package wears out, a shoprag won't filter out anything much smaller than gravel. Stepping over dollars to pick up pennies.:headscrat
sberry
Brethren, Michigan
I agree with coolant replacement. I don't do it as PM normally but when there is a problem I replace in a worthy engine. I will agree that one may not have to take a hose off for this. It is a place where some persistence and trial are worth the effort, be surprised how starters seem to work their way out of impossible spots.
I agree with coolant replacement. I don't do it as PM normally ...
I just replace mine for the first time on an 8 year old car. Looked like new !
I even popped for the recommended Motorcraft coolant as it probably won't be replaced again ! :D
