Thanks guys I bought some picks. Gonna try again in a couple days. (work tomorrow)
Its a gold metal looking.
Go to fordtrucks.com and look in the superduty section, in the stickies is a very detailed thread with photos on changing out front hubs on a 4x4 Ford. I realize that it is for the SuperDuty, but 1999's had 1998 axles in them, and there really hasn't been that much change to them.
Hold the outer snap ring from spinning with one screw driver and pry the end up with another. One end of this ring is beveled so you can get a small flat blade under it.
Huh? The OP's is an '88. There were no '98 F250 or F350 models either. The SD came out in '99 and last of the old body style F250 and F350 was '97. The outers on the front axles of these two are completely different. The Super Duties are a unit bearing design rather than a servicable bearing.
Wrong, there were F250 and F350 of the older body style available new in 98model year, the SuperDuty series actually started shipping in July of 1998, I received mine on July 6, 1998. That is why when you check parts listings for 99 Super Duty trucks you'll find a reference of pre-March 99 or after March 99, pre March has the same axles as the 98 models. I learned this the first time I had to replace the rotors/brake pads. So this also explains why the hubs on the pre-March 99's are $650, versus the $200 to $350 for the after March 99 model.
The old style F250's & F350 were called Heavy Duty series.
TheGrooveking
