Removing mortar and lathe from subfloor
branimal
i am trying to remove mortar and steel lathe ~5/8" thick from the subfloor of my bathroom. It's not the typical cement board flooring. I removed the tile already.
How do you guys recommend I remove it?
A friend contractor friend recommended an sds hammer drill with a chisel attachment set to hammer only. I'm looking at the bosch 7.5 Amp Corded 1 in. SDS-Plus Bulldog Xtreme..
I could take a sledge hammer to the floor as well.
James-W
Southeastern Wisconsin
If it were it would depend on the size of the bathroom. If it's a small bathroom I would use the sledge hammer. If it's a large bathroom, it's time for a power tool.
Zippercat
TN
Or do you have to remove it? If you're going to just retile perhaps you could use thinset and screw down 1/2 inch cement board over the old.
branimal
The bathroom floor level would go up too high for that.
branimal
there area i'd have to sledge is 9'x5'
branimal
Unless damaged, simply thinset over it.
Why? I heard the "right" way to do it is to get it down to the subfloor.
I'm willing to do the work & pay for the tool to get it right.
bczygan
DETROIT! Arsenal of Scrappers
No.....
If you can't get a level surface and good base when you remove the existing tile and any thinset, or if the mortar bed is cracked, then remove it all. Otherwise, if a good stable bed, and the new tiles aren't thicker than the original ones, just reuse the existing bed and set tile in thinset.
Bill
branimal
The mortar had hairline cracks throughout. The mortar had two layers of steel mesh in it.
The SDS hammer and 3 foot pry bar took care of that.
