Hey everyone, to get to the point, I was trying to install an in-wall dog door and ran into this snag. After cutting the hole in the dry wall, I discovered an outlet that prevents the dog door from clearing. This outlet is for a power outlet that leads to the backyard.
I want to remove this outlet since we never use it. The outlet does not feed any other outlet. It appears to have one wire going in and is the end of circuit. I did a lot of research and this is what I'm gathering. I hope you guys can chime in here with what the safest practice is.
1. Remove the outlet, remove wires from outlet, and cap it off with wire nut. (big no no according to the code)
2. Remove the outlet, cap the wires with wire nuts, put it in a junction box. (still a big no no since the junction box is under the dry wall.
3. Unsecure the outlet, remove the staple on the wire, and then tuck the outlet out of the way. (another no no according to the code)
4. Remove the outlet, cut the wire flush. (is this ok?)
See pictures for what I'm dealing with. Any help is appreciated.
