One year ago I diamond-ground my floor (thoroughly) to prep for the HD Rustoleum water-based epoxy. Something went wrong and a year later I have hot-tire-pickup in a few spots.
Time for a new, better coating.
Yesterday I ran to HD to grab a floor machine and their 10-blade, 25-grit diamabrush.
I spent ALL DAY working to get the Rustoluem removed. I have probably 30% removed, but the rest is scuffed down smooth. The areas closest to the doors did come off pretty well, which makes sense (no UV coating was applied).
Questions:
Am I using the correct Diamabrush disk (10-blade, 25-grit)? HD had another one, less aggressive (more blades) but its meant for merely profiling the bare concrete.
I'm assuming where the Rustoleum is very difficult to remove with the floor machine, that would tell me I have good adhesion (more or less). Can I apply my new coating OVER that, as long as it is scuffed down thoroughly with the diamabrush? Like i said, where the was hot-tire-pickup, that DID come off and that is now bare concrete.
I'm about to spend at least the whole morning, again, working to grind the Rustoleum off, but I already spent 7+ hours on it yesterday (800 sq.ft.). It's brutal.
And also - wet or dry? I've tried both and doing it dry is just easier to see where I've been and what I am accomplishing.
Questions:
