burgie
Greetings...
OK...so I bought a used Saylor-Beall compressor (80 gallon vertical tank, 2HP motor w/ Model 703 pump) from Craigslist. After removing all the plugs, including the 2-1/2" one close to the bottom, I inspected the inside of the tank (what I could see anyhow) and it looked pretty good. The tank is strong and solid and holds pressure perfectly.
However, it got me thinking about a rust removal liquid of some sort that I could pour in the tank and let sit for a period of time to clean up (dissolve) some of the light scale rust on the bottom of the tank? (Being a vertical tank only that bottom 3" - 4" has some light scale...the sides look great...).
I have heard about muratic acid, vinegar, a product called "Evapo-Rust", etc...but have no experience using any or these.
Any suggestions?
(PS...I am not looking for a rust converter like POR-15 or other similar product...just something I could pour in, let it do it's magic and then drain).
Thanks much...
Burgie
Any suggestions?
Thanks much...
Burgie
