scooby074
Any tips/tools for removing rust in confined areas?
Im redoing a dump trailer and the floor crossmembers are 16" OC (even less on the last section)
I have been using an electric grinder w/wire wheel and a small RA die grinder with a brush. Also been using a needle scaler.
The trailer deck and frame really limits the angles I can get. The crossmembers are C shaped and only about 3" tall and I cant get much access into the corners or the bottom flange of the C shape due to the deck. I can acces most of the upper flange with the needle scaller.
Even blasting would be hard. Once again the deck of the trailer would prevent getting an angle at the lower flange.
The rust is pretty heavy and scaley. The needle scaler works wonders on it in other areas, but I cant get access. The wire wheels wont let me access the corners either, plus they dont really knock out the rust like the scaler.
Ive also tried my air hammer with a bent chisel. That was sort of OK but not ideal.
Any ideas?
Any ideas?
