Removing Stains On A Cast Iron Table (Scroll Saw)
Crow Horse
Southern Tier, NY
I just picked up a used Craftsman 16" variable speed scroll saw in good condition. All it really needed was a good cleanup. I used a maroon Scotchbrite pad on an orbital sander which did a pretty good job in removing most of the stains. Is there anything else I can try to restore a lustre? Or.....is this the best it will get due to the grind pattern?IMG_4909.JPGIMG_4909.JPGIMG_4910.JPGIMG_4911.JPG
The little specks of black in the grooves? Soak w Simple Green, scrub with the grooves after a while using a cut down used toothbrush. If that doesn't get it I've got nothing.
PoorUB
Fargo, ND
Johnsons paste wax in the yellow can. Any stains you can not get out are patina.
Even with new cast iron machine work srfaces they will get patina sooner or later. You can not fight it!
C
Crow Horse
Southern Tier, NY
Being that Johnson's paste wax has been discontinued, what's a good replacement?
Thanks! It took a fair amount of scrubbing to get it to this point.
cjarvis
JPW may be discontinued but there are a number of others that will work. Search for furniture paste wax.
Wow, guess my three cans for $5 at an estate sale was a steal. Tho they May need the solvent refreshed.
Renegade1LI
long island ny
Depending on how bad the surface is, yours looks good, I start with 120 on the belt sander. I will finish up the table with 1500 & than clear coat so I never have to deal with rust again. Once clear coated a light wax to keep the material moving smooth & touch up with clear as needed.
turner66
Texas
A Surface Conditioning Tool will do the trick if you have one. If not, it's a good reason to add another tool to the arsenal ;)
