Removing steel screw from brass
bluedog225
Texas
there’s always one. This is the group head from the little espresso machine I’m trying to repair. I managed to get all the other screws out with my favorite solution of automatic transmission, fluid and acetone. This one is blind and stuck.
I know if I try and drill this out, I’ll make a mess of it. I’d like to dissolve it out. The candidates are alum, battery acid, and Clorox. All warmed and outside.
As far as I can tell, the alum will be the safest for the brass and generally fine to work with. But I’d like to hear from anybody who has experience doing this.
Thanks
PCustoms
VT
I would NOT use chemicals as that part appears to be plated.
Drilling is really the correct option IMHO
bluedog225
Texas
Tried the alum. Supersaturation. Boiled for several hours. Left overnight wrapped in blanket.
A hot plate would have have been ideal. No got.
Good progress. About done.
kerrynzl
Tauranga, New Zealand
did you try to heat around the screw ?
Brass has a higher coefficient of thermal expansion than steel.
So heating is the way to go.
It also contracts more when cold, I have successfully removed press-in brass bushes by putting the whole component in the freezer so the brass shrinks more than the steel
