Kilgore Trout
So....
The previous owner of my house decided that what appears to be asphalt (bitumen or whatever you want to call it) would be a good substance to slather all over the cracks in my driveway. It looks like **** and over time, cracks have appeared in the tar, so it needs to be removed and replaced before we get the freeze thaw cycles of winter. I pried out all of the tar from the cracks. The cracks are no more than 3/4 of an inch wide (most are about 1/4).
I was planning on filling them with sand, foam backer rod, and then use sikaflex flex seal. However, I am having a hell of a time getting all of the tar off. The sikaflex states it shouldn't be used with bitumen containing materials - my guess is that it doesn't bond well. The tar is removed from the cracks, but there is still a bunch of tar (gobs in some places) on the surface of the concrete (1-2 inches on each side of the crack).
So I am looking for advice on how to remove it. Quite frankly I would like to use the sikaflex, since it looks way better and gets great reviews. But, I need some way to get rid of the tar... I want to slug the previous owner for globbing this crud on there in the first place.
I tried a wire wheel and a grinder - no good. Also tried my electric power washer - also no good...
