kirk.g
Has anyone rented one of those cherry pickers to cut trees with...I got a quote from a tree service and i dont think I can afford 4000.$ for just one tree behind my garage.....There are more but 4K for one in particular.
One tree is a Siberian Elm and is probably 60 ft.The one for 4000$ is a Manitoba Maple its not that tall but has a trunk around 3.5 ft.Here you need a permit for anything wider than 12 inches at the trunk.You 1st need an arborists report to get the permit,these are cosidered weed trees so getting a permit is not a problem......thanks
That is a huge tree. Save the trunk if it's good and slice it up, it would make nice table tops also,as far as what else I need not sure.......Run Forest, Run!
You are not equipped nor have the neccessary knowledge to cut a tree that size.
Smashing your stuff ***** a little bit. Getting killed ***** a lot(which happens by the way, don't kid yourself).
FWIW I do a fair amount of cutting out of a 70' bucket truck, used to do a lot of work with my crane helping a local tree service. Big trees aren't for beginners.
