Repair anti siphon valve
Rizingson
Parker, CO USA-----------------
Last winter an unexpected cold snap caught me off guard, before I shut down the water to a walkout level hose bib. I was able to thaw it out and then shut of an interior valve that's in a heated area that feeds it and drain the line, hoping for the best come spring. But I apparently got the valve too hot and damaged the anti siphon valve on it. This hose bib is behind newly finished drywall, and I'd hate to cut it out to replace the entire valve if just the anti siphon portion can be fixed. At this point it doesn't seem to have any damage to the valve barrel. The valve looks like this and is leaking around the plastic cap which just freely spins on the valve. Can it be removed and a new seat installed?
This happened to two of my outside bibs but I was able to get them flowing at if I heated them up every couple hours through that -17 degree night. (damn that was a long night last fall) Any thoughts or do I need to prepare for the worst:dunno:
zmaxmotorsports
South of omaha
Are your supply lines copper or galvanized?
If theyre galvanized Id just unscrew it and install a new valve,if your water lines are copper it could either be threaded into a female adaptor or sweated on.;)
Showkey
"MEMBER EMERITUS"
Wausau WI
The new valve maybe $20-30 depending on size and location.
Rebuild kit is $4.00 and it's all done on the outside. 10 minute job tops :beer:
Depending on the location, basement ceiling or crawl space getting to the service part of the valve and pipe might be a trick. Also depends a lot on the OP skills and tools available.
rlitman
Long Island
Cap should pry off and part under should screw out
Before you break the cap, I believe it screws off.
The anti-siphon is just a rubber flapper that is held in place by water pressure.
With the water off, gravity will let it fall and open. You turn the water on, and it pops back into place, forming the seal.
The heat you applied probably made it stick to the lower seat, and so it is stuck open. I would open it up, unstick the rubber, and put it back together WITHOUT replacing anything. Then try turning the water back on. If the flapper moves freely, it's probably still fine.
They also sometimes stick to the bottom if you leave the valve off for the season. Happens every so often when I first open the valves in the spring.
Next time you install one of these, they should screw into a female fitting inside the house, so they're easy to change out.
zmaxmotorsports
South of omaha
Until you install the rebuild kit then open the valve to find its split inside.:lol:
Ive done a valve or 2 over the years.;)
rlitman
Long Island
The barrel splits when you leave something attached to the valve, and it sits full of water and freezes (or it isn't installed tilted down as it should be).
But leaking from the vacuum breaker cap is not a symptom of a split valve.
Like it said, it probably does not need a rebuild. The little rubber piece just needs to be unstuck.
Showkey
"MEMBER EMERITUS"
Wausau WI
+2 ^^^^^^^^^^^^^^^^^
dfiler2
NW Minnesota
I'm a little curious what and why you were heating anything on the outside. That is a frost proof valve and the actual valve is inside the heated area. I've never seen one freeze up unless there was a hose left attached to it that was full of water or it would have to tilt down quite a bit.
zmaxmotorsports
South of omaha
So did you read his original post about the surprise freeze and having to thaw things out with a torch,and then shutting off the water to it on the inside?
Im just a poor old retired master plumber with 30 years in the trades.:dunno:
Showkey
"MEMBER EMERITUS"
Wausau WI
Don't you think the OP would have said the anti siphon leaks and there is a huge leak in the basement or it coming out the siding .........since it must have taken some time to frame and take that picture. Also he thawed the pipe so he would likely seen a water leak inside at that time. Just giving the OP some common sense credit.
mygarageone
Munising , Mich
Two things , good luck finding a repair kit and second . I quit trying to repair the things It's hit and miss most times .
I hate going to to fix something after I was just there .
Forget the repair and replace it.
zmaxmotorsports
South of omaha
Water does tend to take the past of least resistance,once you fix the vacuam break in the faucet you may very well find the next path of least resistance is a split in the valve.
Just saying,anything is possible.;)
rlitman
Long Island
Absolutely correct, but there's no way to be sure until you fix it.
Another possibility is that the ceramic valve seat (if this is a quarter turn valve) broke when frozen.
mygarageone
Munising , Mich
This reminds me of my dad , he was always into fixing before replacing , he lived threw the depression era.
But some times do your way ahead of the game to replace it. You could spend multiple trips trying to find the right parts.
Showkey
"MEMBER EMERITUS"
Wausau WI
Yup.........makes real sense to replace a $40 faucet for a $4 dollar repair kit. :lol_hitti:lol_hitti:lol_hitti:lol_hitti
Same thought process is used when the truck needs $200 alternator when it really needs a $12 brush kit. How strange guys in the garage would not be into repairing ????? I get it when the shop or plumber gets a $130 hour. And they just throw parts it until it fixed.......but I can afford to pay myself $130/ hour.
I was thinking guys in a real garage try avoid going to a dealer or worse having anyone make a house call.
Edit.......just back from Menards ( picking up other stuff) they are sold out of the $2.68 rebuild kit, guess there are a few others with the same problem.
R
Rizingson
Yes the hose was left on as I had been watering trees (70 degrees then down to -17 in 10 hrs). When I went out to remove the hose, I couldn't even turn the valve and ice was hanging off it. Even after thawing the valve it required more heat to get water to flow so I could then drain the line. The heat from the torch melted the guide pin of the plastic check valve and it became cocked so it couldn't move up and seal under pressure. I was able to get a complete repair kit including a new seat. Valve barrel was not damaged luckily. Whoever said pipes won't freeze if I left the hose off is pure bs. Especially after you cover exterior wall water pipes with drywall. That's why I had put a separate valve further into the interior with a bleeder to remove all water from that exterior wall pipe before winter hit. The cold was so sudden it killed many junipers and spruces because they need time to adapt for winter.
