Repairing aluminum
bluedog225
Texas
UPS took a bite out the bike I recently purchased used.
Components are worn and I’m doing a frame up rebuild.
I don’t think it’s structurally significant. But I’d like to repair it. Either cosmetically or structurally. Without doing any damage to the remaining metal.
What do you guys think? Something like bondo and repaint or can metal be flowed in without compromising the existing structure? Or something like a clamshell repair. I’m open to any ideas.
Or best just to lightly sand, repaint that little area, and move on. Photos below. The last is a stock photo. The electric motor stuff you see is being removed. It will have a Pinion drive on the front and just a chain tensioner on the rear.
Thanks
whateg01
doo dah, kansas, usa
If it is not structural and you are doing a frame up rebuild, bondo and paint.
bluedog225
Texas
The frame is hinged under the seat. The rear part pivots and has a shock. Strictly touring. But gravel roads.
I don’t know if it’s tube or solid at that point. I was assuming solid. I’ll ask my Azub guy.
The replacement frame piece is about $700 delivered. The guys says it‘s trouble to install. But I don’t know the details. Though well packed by a bike shop, UPS forked the box. And tore it open on one end. They did cover the cost of the new piece. Not the install. And it has to come from Europe.
mrvm
PA
If the replacement cost has been covered I’d use it. IMO there’s enough material past the divot and supporting structure left to handle road load…….SEND IT
matt_i
I'd run it until it breaks, if that's ever.
Going to have to strip paint all around, some is going to get burned by the radiant heat. Likely never get it coated back the same.
It's in the thicker cross section above where it's already joined to the flat stock. That top tube of the triangle is mostly in compression.
bluedog225
Texas
I looked into frame builders around here that deal with alu. And talked to the Texas dealer. He thinks it’s good to go. Even given his financial incentive to sell a new part. And the tig welding introduces a bunch of complications.
I’m going bondo and spray paint. Haven’t done that since 1980.
Thanks all.
MOwens
I would tig weld that back in myself. But I am also a machinist/welder with some certs. Any decent welding shop should be able to fix that right up.
bluedog225
Texas
My light research indicated that the bike frame alloy surrounding the weld would need to be heat treated to restore its strength. Which is a hole can of worms. Any idea if that’s true?
35Ford
Central MA
Epoxy filler, sand, mask and paint. Then wrap the repaired area with one wrap of red reflective tape. Put a wrap of tape on the other side to match.
Firebrick43
West central Indiana
Was the frame heat treated to begin with? I could find no mention of it and its not common with many manufactures unless they are going for minimum weight which seems to be the opposite goal of azub, to make a durable long life frame with large diameters and heavier gauge tubing.
Its actually insane to me that that tube is not worn thru and has a hole in it. That is some thick tubing.
If UPS is paying for a new one why not replace it. It looks very easy and straight forward to replace it, especially if you are removing the electric motor anyways, that is where the majority of the work with the wheel set and derailleur would be anyways. its just a pivot point and shock mount other wise.
bluedog225
Texas
Thanks. I’m checking on the heat treatment.
bluedog225
Texas
All I have is this from the website. Waiting on a response to the email.
“Built from specially developed thin-wall AL 7020 tubing, the asymmetric rear fork delivers exceptional stiffness at extremely low weight.”
