MatBirch
I don’t have cracks, but large sections that need to be patched, leveled and skim coated. It’s an exterior foundation wall. As you can see, I’ve removed all the loose, spalling concrete. Still need to wire brush it and vacuum it, but I’m looking for the best product to resurface it with. Bonding agents? Sealers? Etc.
the foundation was done in 1905, so it’s given pretty good life! I realize that the likely cause is moisture migration. The primary areas are the first 18” or so below grade on the outside. I’ve repaired a leaking exterior faucet on this wall and added gutters that it never had. Climate here is high desert, so continual moisture shouldn’t be an issue, but I know any kind of coating on concrete is susceptible to being “pushed off” by moisture within the wall.
