Repairing egged out hole
dante2
Central OK
I have a pair of brackets that are close to 20 years old and 640+ hours of service on a mower deck. The bracket is discontinued and unavailable in this universe. The hole originally was 7/8" and accepted a bushing and bolt through it. My only option is a repair of the oblong hole. Can I use a 7/8" brass bushing and fill the gap back in with a mig welder? My plan was flat copper on the table and clamp the bracket over that. Then clamp the brass bushing to the original intact edge and fill the oblong gap. Am I going to have a problem with the brass sticking? Any thoughts or suggestions are greatly appreciated. TIA
  • CUB-CADET-783-05118-Idler-Bracket-LT-1045-1046-i1046-ZTT46-0637_68657b8e-bed8-4aba-bc85-d7e27...jpeg
bwringer
Indianapolis
I think you'll melt the brass bushing, if you're talking about welding with the bushing in place.
I'd just locate the center as best you can, then fill the hole with weld and re-drill.
To keep the drill bit on track (drilling through weld can be, er, interesting), perhaps drill a 7/8 hole in a hunka steel plate, tack weld it on, then use that as sort of a drill guide. (You could also start with a smaller hole like 1/4" and work your way up from there; might be easier.) And/or if there's room in the mechanism, maybe you could leave the doubler in place after trimming and welding it properly, and maybe end up with a much sturdier part.
D
dante2
Central OK
Unfortunately that's it on the thickness. Looks like a fill and drill job. Just time and I have plenty of that. Thanks for the help now I need to get a 7/8" bit.
D
dante2
Central OK
are you able to weld a nut to the flange and then thread the bolt with the bushing in place?
I don't think so. This is the bushing and the 2 brackets are stacked with the bolt thru the deck. No real tolerance for anything else since everything little thing effects the belt angle.
RoninB4
Under My House
-Drilling a partial hole, an interrupted cut, is going to be a bit sketchy with a drill press. The excess weld/braze on the worn side will tend to push a drill over to the other side. It will either snag, catch, of go off center even if the part is clamped to the table. Do you have a milling machine or a lathe? You do what you want to but you're intent on using a drill press I'd strongly suggest using quill feed control in the order of .007 down-feed on a peck cycle. If you use a twist drill it can snag, break the drill, mangle the bracket, and/or launch the workpiece. If you're using steel for filler your cutting speed will need to be fairly slow (making it more snag prone) or a carbide cutter will be needed. This is all the more reason to do this in a mill or lathe. Better results, better control, more cutter options this way.
If you were closer I'd have you bring it over and do it while you watched/learned. If you're going to use a brass (or other material....) bushing then now would be a good time to plan of employing a replaceable bushing into the design for next time. Wear properties for brass aren't very good for some things. Post your intentions.
jbltwin1
Godfrey, IL
Weld up the egged out part and get the router bits out and re-round it. Or weld the hole up and re-drill. I've done both. Actually, just did something similar on JD pivot bracket. It had a 1/2" steel boss on a 3/16" or so bracket with a .502 hole for a shouldered bolt. . I elected to just cut the boss off, center bore a 1/2" hole in a piece of 1" stock. Cut it roughly to length and then turn it square and length on the lathe. Stick reamed it an extra .002 for slip clearance and them MIG'd it on bracket. Easy peasy.
Caneil
Vermont, Earth, sometimes
Could use a piece of graphite rod that's the diameter of the hole you want. Put it where you want the hole, weld right up against it. Even if one has to break it up to get it out, the diameter and location are still right.
rsanter
visalia ca
You use copper as a resist to mig welding, not brass
just lay some weld in the hole where it got oblonged and then die drinker to make round again
rlitman
Long Island
...now I need to get a 7/8" bit.
I strongly suggest not doing that. The step drill is your friend here. Especially when it comes to situations like this, step drills with their long circular wedding cake stair steps drag on the edges of the hole, keeping the bit well centered and the hole round. A regular twist drill is going to bite into the edge and that's going to **** when you find out that the welded edge goes from hard to soft all over the place. You'll end up with a real ugly hole, if it doesn't break the drill bit or throw your part.
Or, if you don't mind a perfect fit, welding just the worn side and then die grinding back to round is an option.
D
dante2
Central OK
I got the worst one done. I'm pretty sure the 3/4-7/8 is shot on 2 different step bits. I also found out my drill press really isn't up to the task either. The other bracket isn't as bad so I think I'm going to add a little to the low side and grind it into shape. Any recommendations on a good bench drill press?
HoosierBuddy
Southern Indiana
If it was me and I had to have one fast, I'd probably at least try to order this Wen, which appears to be kind of a 12-inch Jet clone, because of all the features and I have bought a few Wen items, such as a dust collector, and have found there stuff to be surprisingly well built.
If I had the time? I'd scour FaceBook marketplace or Craigslist and find a nice US made one from the 1960's to 1980's. Even the consumer ones like my old Craftsman are well built. Although they lack features like variable speed drive or digital readout or laser targeting....they will absolutely drill holes in anything you put under the bit (including the table if you're not careful). Can be found for not a lot of money and will outlast us all.
rlitman
Long Island
I got the worst one done. I'm pretty sure the 3/4-7/8 is shot on 2 different step bits. I also found out my drill press really isn't up to the task either. The other bracket isn't as bad so I think I'm going to add a little to the low side and grind it into shape...
In theory, you can pretty easily use an angle grinder to bring back the edge of a step drill and remove the rounded corner back to sharpness. In practice, step drills are so cheap at HF that I'll admit to never bothering with this.
But yeah, cutting through a mix of weld and heat affected steel is hella hard on any drill bit. At least a step drill makes it a moderately controlled experience. Good luck with the grinding. I'd use a 1/4" solid carbide (and a full face shield, because the needles a carbide throws are something awful), and hold on tight, because the one thing you absolutely MUST avoid while die grinding inside a circular hole is the grinding climbing away and pulling you around the circle. That gets violent fast. Having a smaller cutting edge (one that has a lot of space in the hole) helps.
D
dante2
Central OK
Plenty of time and the Wen 4212 still works but it took a beating. This one just doesn't have the amperage for big projects.
D
dante2
Central OK
They were pretty cheap bits thankfully so no great lose. I've played the chip game more than a few times, they get everywhere. Anytime I grab a grinder out come the gloves and face shield. The grinding should go a lot faster since I don't have to add much to the second one.
RoninB4
Under My House
-A drill press, no matter who makes it, is entirely the wrong machine for the job. You've already found this out.
-Nothing for a reasonable cost except a used square column mini-mill for work like that. The round column mills may work but I consider them a lesser design for milling. Both will have the rigidity that you'd want, a drill press (even a large radial model) won't be capable of holding the cutter solidly due to side loading. A drill press is only capable of up/down loading, don't even consider one of those awful graduated X-Y tables for milling with a drill press.
D
dante2
Central OK
I don't have space for another machine at this point. This was a one off thing that likely won't have to be repeated. I work more with wood and cars than I do metal fab. Thank you for the info though.
danielbuck
eh, I'm pretty sure an annular cutter in a drill press would have no problem doing this. I've drilled holes 1/2 off center of an existing hole with a drill press and an annular cutter no problem.
RoninB4
Under My House
-eh, I'm pretty sure you've only done this once/twice and declared it a safe/reliable process. A pity we (toolmakers) can't be fearless in machining like you've stated, especially when giving out advice to a novice for a sight unseen application. Gee, what could go wrong?
-No surprise you've drilled 1/2 off center. The number of cutting edges engaged in the cut make a difference, same as TPI-to-stock thickness like a saw blade. A weldment also has different cutting condition behavior than the base material. You can make open suggestions but when you reply with a quote you should be able to qualify that position with more than an opinion derived from infrequent instances. Gee, what was I thinking comparing my 35+ years of machining to your occasional week end garage projects?
-You do you but I wouldn't recommend anybody follow your machining practices without a few caveats, safety topping the list.
danielbuck
he's literally talking about fixing a 1-off part, not making 100 of them. you don't need 35 years of experience to use a drill press. I have no doubt you're more capable than I am, but I've built and modified alot of things, including yes... drilling through welds. You can do alot with a drill press, dude is not going to buy a machine shop to fix this 1 part.
RoninB4
Under My House
-Production numbers have no bearing here, it only takes one for bad things to happen.
-Some people can't foresee the factors that lead to bad things occurring if they have little experience. The greater number of industrial accidents occur with 1) Newbies 2) Experienced workers that have gotten too casual with potential danger.
-I'm not interested in d*ck measuring or who's better. My viewpoint is to advise so cutters don't shatter, a workpiece isn't ruined, and (most importantly) there isn't a life altering injury. Advice without safety precautions is bad advice.
-Perhaps you have, I won't dispute your past experience. But if you've never had a machining process go sideways then you're not really paying attention to reality or the potential. You do you as you see fit to.
-Thanks for the info, I've run a few of them. I guess you know that there's a world of difference between a HF table top model and a large radial drill press. It isn't just the physical size or motor horse power. The OP even posted that he found out his drill press isn't up to the task before your first reply. Did you even ask what he was going to use? Would that make a difference? Why would that make a difference? What would be the length of the annular cutter? Why would that make a difference? Locking the part in against rotation if/when the cutter bites too much? How about down-feed control and/or quill stops or is hand feed ok? Why would that make a difference? Are my questions important and why are they important? Apparently they aren't important to you and there's already too much bad advice out there on the internet with the potential for injury when a novice follows that bad advice. Not your concern huh?
-Reading and comprehension are two different subjects for you? In neither of my posts did I suggest going out to "buy a machine shop". The absurd comment above doesn't further prove your point either. I've had my fill of pointless bickering with some amateur garage hack that foolishly ignores safety precautions. You can have the last word, your ego probably needs to have that.
sqznby
Coastal NC
Had to do the same thing to some old hangers for my Chevy.
Located the holes, laid it out outside where I was going to be grinding the weld that I filled them in with. Ground down the weld and used those lay out marks to locate new hole. Used my optical punch on my scribe marks, pre-drilled the holes and chased with a couple of others because I didn't have a step bit with me. I used my hand-held electric drill because I was out of the shop. Lined up perfectly after.
It's really not that difficult.
htmdude57
Hudson Valley, New York
Would either of these look like what you need?
MJD1
Good God it's a mower deck not the space shuttle. Weld it up grind it down , drill a pilot hole and run a car reamer thru it. Certainly doesn't require 2 tons and 10,000$ of machining equipment to fix an egged out hole.
D
dante2
Central OK
Good find, that's strange those 2 sites never came up in a search. I actually found another low hour mower that is in great condition with a cracked block. Going to combine them and strip the other of all it's usable parts.
