I'll try to be brief.
Our house has a 1/2 hp screw drive door opener. It works fine, except I want the auto close and internet access that the newer openers have (heck, all I really want is auto close after 10 mins, as my wife and I have both left it open, and were lucky nothing was stolen).
To upgrade our door, is $75 (https://www.amazon.com/LiftMaster-M...id=1484087813&sr=8-1&keywords=myQ+upgrade+kit)
However, for $175 - $200, I could get a new opener which comes with this kit, rather than a retro kit which has patchy reviews. It'd be belt drive though.
http://www.sears.com/craftsman-190-hps-ultra-quiet-belt-drive-garage/p-00954918000P?plpSellerId=Sears&prdNo=7&blockNo=7&blockType=G7
Question time:
1) Is it actually a downgrade to go from screw drive to belt drive? The screwdriver says ''professional'' on it ...
2) The screw drive opener is installed (by a professional) on an angle and hangs down. Could it be that a belt drive won't fit? Watching the door open, I 99% believe the angle is just because the installed couldn't be bothered adjusting the original brackets for the original door opener motor. Regardless of what I do, I will be adjusting the way it mounts to raise it up (to be out of the way more).
If I go with a new opener, I'm assuming I can swap it over myself and not have an installation fee. I do plan to switch the garage door out for a sectional roller with wall mounted motor in a couple of years, when time and funds allow ... however I'm realistic that bathroom remodels, patio and other projects will probably delay this indefinitely.
What would you do?
Question time:
What would you do?
