I am in the process of converting a previously unheated single car integral garage into a work area. The garage is approximately 12' x 35'. The garage has a low ceiling height at around 6' 8" from floor to the bottom of the unfinished joists above, and current door opening is 8' wide by 6' 3" high. The garage will now be heated/cooled so I want to get a new door on it to help with insulating the room. I'm considering either a new insulated 8' wide by 6' high garage door, or a double steel door which would leave enough room to move large appliance in and out and allow for storing a few motorcycles in the garage. Has anyone here replaced a single car garage door with a double door before? I am interested in any opinions on this as well as the pros/cons of it. I know with the doors the "garage" will no longer be able to be used for cars, but this shouldn't be a problem and with the low ceiling height it's just about useless for this now anyway. My main concerns and reason for changing the door in the first place is getting it insulated better and the old door is in really bad shape. The concern with the double door is how to take up the difference in size on each side of the doors to make up the existing 8' opening. Both sides are currently block foundation with rounded edges at the door opening.
