While I'm still messing around with a lighting and outlet plan for my attached garage, I want to proceed with the sub panel installation. I'm not an electrician or have stayed at a Holiday Inn recently.
I'll be hiring a pro for most or all of the work and would like a better understanding for our discussion.
My current demands for the garage are small and include several circuits for lighting, several 120v outlets, a couple of 240v outlets for a compressor, and garage door opener. I may add a welder in the future to one 240 outlet.
The main panel is a 150A Challenger panel. The panel is running out of space and I'm unsure if it can or should accommodate a 60A breaker for the sub panel.
If we plan to stay in the house, is it recommended to replace the main panel with a 200A Square D AO and use the 150A Challenger panel in the garage feeding it for 60A or 80A? Alternatively, don't use the Challenger and go with a Square D both main and sub panel?
The run from panel to sub panel would be 40' across the basement ceiling with three 90 degree turns. Part of the run would be along the wall and through a dropped part of the ceiling to run along an open area by the furnace. Is 2-2-2-4 AL SER optimal for the run and can it be installed within PVC or EMT conduit for protection?
Thanks for taking the time to read and respond! Below is a picture of the main and manufacturer's label.
