MushCreek
I've had the same engine hoist (cherry picker) for about 30 years. I've done a ton of work with it (oddly enough, only one engine, though), such as moving heavy machinery. And that's where the problem lies. Sure, it will pick up a 2000 lb. machine, but good luck moving it! The casters are cheap ****. They won't swivel under a load, and won't roll well, either.
I decided to put better casters under it, but can't seem to find 1000 lb. or better casters that are low enough. If I put 4" casters on it, I'll run into clearance problems at times. I've had that problem even with the lower casters it now has. Any suggestions? Do they make a really low caster that can handle that kind of load? The problem is that when you pick something up, about 90% of the load is on the front two casters.
