DandDMachine
I have a old Toro snow blower (probably 80's vintage) with a Tecumseh engine on it. I don't remember but its either 5 or 6 HP. While using last year it just quit running while using it. I suspect a broken connecting rod as it now spins over way to easy. Was too cold outside to mess with it and just put it away for the season. I paid $50 for the whole thing and used it for almost a year. Now its coming up on snow season again and time too get it fixed.
I was thinking about getting one of the cheap Predator engines from Harbor Freight. http://www.harborfreight.com/engine...-engine-69730.html#pr-header-back-to-top-link I believe that most snow blower engines carburetors are designed to run in colder weather. The HF engines are a generic replacement and probably not cold weather calibrated. Do you guys know if that would be a problem with this engine? Has anyone done the swap? I can get one for about $100.
Option #2 a Kohler engine from Northern Tool. Its about $300 but I know my experience with Kohler engines has been good, and its designed for winter use. If I end up having problems with the HF engine I am sure I will forget about the $200 difference when its below zero outside and my fingers are freezing. http://www.northerntool.com/shop/tools/product_200436508_200436508
Option #3 fix original engine assuming broken rod and the block, crank, cam etc... itself is ok, The engine seemed tired but still ran ok until it quit. Had fuel leak from carb. Since I run a engine building shop I can do all of the machine work to rebuild it myself at no cost of labor but parts are getting hard to find for the Tecumseh engines and they aren't that cheap anymore.
I don't want to spend too much money on this deal but any other suggestions would be welcome.
: dpeneding on what you winter climate is like you may have to modify the stock jetting for best results, very easy to do.
