replacing a 1950's garage sink faucet
Vividlyvintage
I have a leaky faucet in my garage. I am trying to find a replacement or find something that will work. This set up is obviously different than a kitchen or bathroom faucet. Does anyone know how I can either make it so a newer faucet will fit onto this setup or where I can find a replacement? Any and all help is greatly appreciated.
yeldogt
That is interesting!
So ....... the hot water stem broke off?
Most of those old style stems are still available -- as long as the seat inside is OK or can be cleaned up you should be able to fix it.
I just replaced a set from a bar sink from the 50's -- my local hardware store had it. You may not find it at the big box stores.
SteveCh
I had to replace some parts on an old [40s??] sink faucet a few yr. back. I had no luck at any brick-and-mortar places. Even after talking my way into a couple of wholesale, huge supply houses.
I spent endless hours searching on the web. Gave up a few times. Finally, I did find what I needed on the web. The parts were costly, but in my situation there was not much I could do but replace the entire sink outfit if I couldn't repair the faucet.
Keep looking. I have never seen anything like what you have there.
metalart
plumbing supply store carries these. They are typically used in commercial applications
