BK777
We had our house re-sided a couple years ago. They did a pretty good job but cut a few corners. I think this is one of them. It looks like, rather than removing this light & flashing around it, they just cut a hole for it and caulked if afterwards. I can't believe I didn't notice this when we were doing final walkthroughs.
In any case, I'm looking to replace this light now. I'm pretty sure, once I cut the caulk and remove it, I'll see a hole with the old siding behind it. So I'm sure I'll be able to slide things behind it. The new light is a similar design, but slightly smaller.
What would be the ideal way to flash this? I know they make blocks for this kind of thing but it looks like they were intended to go under the siding at the time of installation. I don't want to remove any siding if I can help it. There's a small chance I'll be able to take the front half off, leaving the base attached & just attach the new light to the old base. But I won't know until I take it apart. It's hard to tell from the pic but the new light should fit inside the base area.
This side of the house is exposed to everything. Lots of sun & lots of rain.
