GN4WHLN
I need to replace two support posts on my patio cover. They are rotting on the bottom because they sat in water for years prior to when I bought the house. They also seem small for the load they hold and a poorly designed support system for a home in an earthquake area.
If you look at the bottom, they are held in place by a bracket in the cement and the bracket was set too close to the edge and has cracked some of the edge piece away. The patio was built by the builder and is an optional room so it sits on an extension of the slab. Below it is an exposed patio I put in.
On the top, it has a 4x6 header that supports one of the open sides of the cover. Two other sides are supported by the house. The structure is 2x6 on 12" covered in sheet and mineral roll. It looks fairly heavy for a 20'X30' patio cover.
What I want to do is replace the 4x4's with 6x6's. I've thought about sistering the 4x6 header with another and shifting the 6x6's back away from the edge a little. As far as brackets to bolt it together, I will probably have to make the top ones. I am more than capable enough to design, cut, and weld them from 1/4 plate. What I am not sure about is what to do with the bottom. Can I simply bolt new mounts to the cement? Do I need to epoxy the anchors in?
One thing I thought about was casting a cement pier to support a new mount, but I have no idea if this would be structurally sound. It would seem so, but actuality is often something else.
Any help would be appreciated.
