Replacing asphalt driveway with pavers
Mike65
Horse Pasture, Va.
At our last house in NJ, we removed the old 1 car wide 2 car long asphalt driveway & had a 2 car wide concrete driveway installed. The driveway would have looked great with a paver's but having to use a snowblower or plow on it would be a PITA IMHO.
Montauket
We did ours in pavers about 5-6 years ago. I did a 8" base of rebar reinforced poured concrete then came over it with the screed material and compacted then pavers. I designed it to park 20,000 lbs with never the worry of it getting wavy. This weekend was the first time I had to clean it up with the pressure washer to get the acid rain blackness off of it. 25x40 cost me a gallon of gas and 70 bucks for 2 bags(still have 3/4 of a bag left over) of polymeric sand. I have not had any issue with the polymeric and ants/weeds with non poly sand you would. Once in a blue you'll get a little moss on top of the sand in the shady spots but it comes up easy. Nylon ski's on the snow blower and no problems. I had asphalt before and couldn't wait to get rid of it. Wavy as hell, cracks, patches from hot tires , sealing every year. I'll take the pavers over asphalt. Upstate at the hunting camp we have gravel about once every 15 years we need to order a load for an 18 x 150 and I just spread it with the box blabe or york rake. We had asphalt before up there and the frost heave played havoc on it all the time.
I
ive
Canada
Hi.
I did a walk down the side of the driveway a few years ago and it’s holding up nice.
I
ive
Canada
-Where are you in Canada?
-Why has the asphalt failed - age, load, weather?
-Why hpb? I have sidewalk supervised several large brick instalations and they are using sand.
IMHO opinion, preparation, preparation preparation is the key to success.
In Toronto.
I will prep. Project for next summer probably. Too much normal work this year
Codyboy
S.E. TEXAS
I’d go with about 8–12 inches of compacted base, depending on soil. I’ve had better luck with 3/4 gravel for drainage, then a thin layer of HPB just for leveling.
Thread I'd really old and never followed up on.
But I hope op has a lot of stamina if he does or did lay pavers
Heck I'd do stained and patterned concrete. Before I was on hands and knees doing pavers on a large project like his.
K13
St. Albert, AB Canada
Pavers that size are going to be a nightmare to lay and get flat. Pavers have to go straight down so as to not disrupt the sand layer or you will have a base. You are never going to be able to do that with blocks that size if you have never done it before.
Higgins
Shepheardsville, KY
Pavers are all about the base. You cannot overdo the base. But if you "under-do" the base it will be obvious in less than two years. The base, especially in anything in the snow/frost/ice belt must have at least an 8" base of compacted gravel (at minimum) on top of compacted subsoil. Then, about 2" of screeded sand atop the compacted base, then a layer of weed block fabric, then after setting the pavers, use a compactor on top of the pavers to set them into the screeded sand. Then use the right polymeric sand to broom into the pavers joints. If you don't use polymeric sand, as I found out, eventually the damn ants WILL dig through the sand and create their domains under the pavers, leaving little sand mounds atop the pavers. Over time the pavers will then sag into the cavities dug out by the ants. Also, weeds WILL grow into the regular sand between the pavers and then your maintenance changes to eliminating/pulling weeds, which leaves distrubed sand between the pavers, which invites the ants, which,...well you get the idea.
I do like the look of a paver driveway, carport or patio. But without all the extra work to do a proper base, it'll look like **** within five years.
LOTS more work up front to do it right the first time will avoid LOTS more work about three years after you laid the pavers.
But go to Europe, and many roads in the cities are some form of pavers or quartz cut stones set on a very stable base.
I would suggest applying several applications of weed killer to the sand before putting down the fabric.
