Replacing flooring.
Coach James
Sandhills of North Carolina
I have to replace more of the vinyl floor tiles in my building. They are the 12"x12" commercial vinyl tiles. The subfloor is plywood. Can I just sand off the old adhesive, put down new adhesive and install the tiles or should I try to scrape the old glue off? I don't want to gouge the plywood and have more problems.
I asked the guys at Lowes and had no faith in their answer which was "Yea that should work.". Translation "We have no idea".
Thanks
Coach
mikevango
erie, PA
best bet is to tear up the tiles and subfloor. or tear up just the tiles and put a new subfloor over the old one. the old adhesive will probably be a little sticky still pending on how old the tiles are and will not really be sandable.
mikevango
erie, PA
ok. good. after the old tiles are removed, i now will recommend that you use a new 1/4 plywood subfloor. this will give you the best results. or even better hire a pro
