Replacing Hard Wired Smoke Alarms
oldcpecdr
Cape Cod
Evening all
I have three hardwired smoke detectors in the apt I built for my Dad in 2000.
They are 17 years old and I am getting an intermittent alarm so time to replace !!!!
I would like to get a combo smoke and CO detector this time.Anyone have a suggestion for a good hardwired brand and model ? I do NOT need an internet capable alarm.
Lots of conflicting info on web and in feedback on various models.
Thanks
Mike B
ard
Sierra Foothills... California
Unless the detectors are down low, I wonder if the CO is a benefit.
Ive used Kidde detectors in the past, not sure what they have now. I believe they have combo 'heat and smoke' detectors. Can be better with some types of fires....
NUTTSGT
Northern Central Ohio
Personally, I'd prefer to have separate units, like a Nighthawk with a digital read out that plugs into the wall for the CO.
Currently at work, we are doing a program with the assistance of the Red Cross. They are providing the detectors and paperwork and we are installing them. I can't remember what brand they are but have a 10 year battery in them. Once they are hung up, all you need to do is test them monthly and in ten years, toss them out and hang a new one. They have a spot on the side for the date but I'm not sure if that will be legible in 10 years.
LXCam
As suggested I don't recommend the combos and the CO's should be 2-3 ft above floor level to be the most effective imo
The Cobbler
co mixes with the air so anywhere is fine for them. I have interconnected smokes with battery back up and a combo co/smoke on one of them.
not sure of the brand now, but I feel safe with them
The air we breathe is composed of 80% Nitrogen, 19% Oxygen, .6% inert gases and .4% Carbon Dioxide. So how does CO compare with air? It is 3% lighter. ... But when CO is produced, it immediately begins mixing, and therefore diluting, with the air around it.
captaindiode
NC
I just replaced all of mine in a house built in 2000. They are supposed to be replaced every 10 years, and I had intermittent alarms too, always at night. I used BRK (First Alert) from Lowe's. I did one CO/ ionization in the hall and basement and combo ionization and photoelectric everywhere else. I used AA lithium batteries in them. The CO detectors lose sensitivity after about 6 years, according to what I read.
You can also get a standalone CO/gas leak detector like this:
https://www.amazon.com/dp/B0002EVNJ6/?tag=atomicindus08-20
O
oldcpecdr
Cape Cod
So
Conflicting info.. ok ordering two combo units smoke and CO, for kitchen and downstairs hall, smoke only with separate CO for upstairs BR
THAt oughta cover it.
ard
Question for all:
I don't have a CO upstairs, simply because the upstairs and downstairs are 'connected' (open atrium). But even if it was a simple open staircase.... I assumed the CO will pool downstairs and trip the alarm there. Alarm is located 14" above the floor.
OK?
Upstairs bedroom doors never closed.
Thoughts?
