Replacing Odd Support Posts in Basement
OldPartTimer
I have an older house with support posts in my basement. The basement is 40 feet long and has two support posts. Apparently, when the house was built the posts on hand were too short. So, a hump about 6 inches high and about 2 feet in diameter, which slopes, was added underneath them. I especially need to get rid of one of the humps. I need to lay flooring there.
I believe my options are as follows:
Option #1 - Add another longer post nearby to support the beam, level the hump, and replace the post with a longer post.
Option #2 - Add two more posts to cover the space, remove the original post, and remove the hump. I could probably cover the posts if I could move them.
Anyone know the best way to do this?
Thank you.
red61cj5
West Virginia
Easy, go to lumber yard and get 3 adjustable lolly columns, put one on each side of the hump and adjust them up to your beam, remove the original column, remove the hump, smooth out the floor, and put the third column in place of the original one. remove the two side columns and return them to the store. Frame and box the column in some nice wood.
Leaflessshadetree
Don't ask.
Is it possible that the "hump" is possibly the footing at the base the column and the floor was added afterwards but at a lower level to allow some headroom?
pstnbly
So. Vermont
^^^^^ this + 1
Bondo
Greenfield, Maine
Ayuh,.... A hump, of What,..??
larry_g
oregon
Be careful here, that sounds like a footing to me also. I suspect Leafless is on the right track.
lg
no neat sig line
O
OldPartTimer
The footing idea makes sense. How would that footing have been constructed? And, how should it be rebuilt?
Thanks.
csp
Franktown, CO
The footing would most likely be another concrete pad under the floor.
Footings get poured first, then finished floor goes in once the columns are in place.
mrpizza
IL
Sounds like a footing, i agree with the others. Also, if you use posts from the store dont return them after, tbats shady. Besides, you might need them later.
O
OldPartTimer
So, what if I support the beam, take the old one out, level the "hump," smooth the concrete with more concrete, and put a new post in its place? Will that work or do I need to do more?
Thanks.
acer66
Western North Carolina
I my exes basement had the same thing and I was told by an old timer that this is quite common when the basement has water issues which is normal around here for older houses to get the post out of the flood zone.
Hawk
Kannapolis, NC
Thanks.
That "may" work, or you may be weakening (thinning) the footing. The best thing is to get a local engineer to check it out. Or second best would be to brace the beam with the lolly post, dig out the old footings, replace with the proper depth footings for your area. Thene replace the column.
APEowner
Sunny, New Mexico
You have to be careful with your temporary support posts as well. The floor next to the footing may not be strong enough to support the post and there's sometimes a joint in the beam at the existing post that requires additional attention when building the temporary support.
hh76
NE Wisconsin
Probably a good time to have an engineer take a look. Knowing how some older homes were built, might be good for them to review column locations/beam spans to avoid any future issues.
engineer2
Chicago burbs
I know someone who got rid of their posts in the middle of the basement. They bought a steel H-beam of the right size and length and got it in through a basement window. Supported it on both ends with adjustable steel columns. It really opened up the space. You have to do a load calculation to size the beam. There should be online calculators for this. Google L/360 calculator. Results may vary depending on what's upstairs.
mmb617
PA
Really? You're kidding, right?
It always surprises me that a lot of people don't see anything wrong with that sort of thing. :dunno:
I've heard of women "buying" a dress for some special occasion then returning it after wearing it to that event. I don't see the column return as any different. Still wrong.
woodzy
Se Michigan
On my house, they poured concrete 12" thick in about a 2' diameter puck at the level of the stones under the concrete floor at each column location. They added the adjustable column's built the house and then poured the entire 4" floor to cement them in place. I would think you need more than just the concrete floor to support the weight of the floor above.
