I recently purchased two used Snap-on 1/4 inch drive, 1/4 inch hex bit sockets, model number TMA8 with a 1985 date code.
When I placed my order, I was under the mistaken impression that the bits were secured with a set screw. Upon receipt, I found that the bits were secured with a roll pin instead. I was able to remove the bits from both bit sockets without issue.
My intention is to replace the 1/4 inch OEM bit with a PB Swiss C6 security hex bit. Unfortunately, that the socket uses a roll pin instead of a set screw might pose a problem. As I see it, I have five options:
Option 1 seems impractical, and I'd like to avoid option 5.
Option 2 is most appealing. The roll pin holes appear to be approximately 2.5 millimeters in diameter, making an M3 set screw appropriate. However, the holes (one for each socket) will need to be tapped. I'm concerned about the hardness of the socket making thread tapping difficult, if not impossible. I don't want to destroy the sockets or damage the tap, which will likely be a borrowed tool.
Is option 2 possible? If so, are there any special precautions I should take? Or should I be looking at options 3 or 4 instead?
- Drill the PB Swiss bit for the roll pin.
- Tap one of the roll pin holes in the socket to accept a set screw (M3x0.5, about 3mm in length).
- Use some sort of epoxy, e.g., JB Weld, to secure the C6 bit in the socket, presumably creating a permanent bond.
- Use thread locking compound to secure the C6 bit in the socket, creating a semi-permanent bond.
- Abandon the project.
