Hohn
Nothing can stop a Trane? Well, a design flaw like copper tubes touching galvanized headers on the evaporator sure seems to. That said, nearly 20 years isn't a bad run. But it's aggravating to have replace the system in the peak of summer for a preventable failure.
Anyway, this Trane setup from 2005 is an XB10 air conditioner and an XB90 furnace (presumable 90k BTU?).
I've never liked this system from the day we moved in and I noticed the furnace filter (a wimpy 14x20x1) was installed in a way that the airflow was LIFTING IT OFF THE SEAL. A truly dim apprentice laid this out. I had to call the number on the sticker to get them to install another filter anchor so the instead of entirely going around the filter it would have less leakage.
The air mover velocity-- even with a fresh filter and clean ducts-- is pitiful. You can barely tell any air at all is coming out when it's running.
The furnace seems "ok" but has needed a couple small parts replaced over the years. It's gas, not much to go wrong.
The basic ductwork in the house doesn't seem too bad-- the main trunk seems quite generous (about 2ft wide and maybe a foot tall). It runs through the floor of our full-basement ranch house, and is now enclosed when the basement was finished.
This is going to be expensive but hopefully I'll end up with something better when all is said and done.
Local dealer of good repute carries Lennox primarily. I'm so jaded I just assume everything is garbage now, but apparently they have an all-aluminum evaporator that appeals to me.
I wouldn't have thought to buy Lennox necessarily but I'm inclined to think that since almost everything can be junk, I'd shop local dealers and installers primarily and just buy whatever they sell and support.
