always hopeful
Currently have two single doors with 7'0" x 8'0" holes and 1'0" center post. With post removed 17'0" x 7'0" inside to inside dimension for new double door. Each single door hole is support be traditional 2x8x8' header. Don't want to remove exterior 2x8 from header for fear of damaging the stucco.
#1 option. Remove on the interior 2x8x8' from of each existing header and
2'0" from the center end to the 1/2" plywood that was between the two 2x8x8's making the existing headers. Replace removed two foot of 1/2" ply with a 3'0" piece that would wedge a piece of 2x into the void between the two remaining exterior pieces of 2x8x8' (glue and screw into place).
Secure a new 2x8x18' replacing both interior header 2x8x8' supporting it on each end with existing 2x6. This makes a replacement header that has two 2x8 with a former center post space filled with a 2x spacer held in place by 1/2 plywood, and a 2x8x18' exterior beam replacing two pieces of 2x8x8'.
#2 option. Same removal technique, but instead of using a 2x8x18' use a 1 3/4"x 71/4" x 18'0" laminated micro beam. 1/4" plywood would have to be added to the space above the header from the header to the joists, and on the face of the 2x6 end supports to make the overall surface flush and facilitate hanging the new door.
#3 option. Do not remove the existing header. Glue and screw 2x stock to fill the space between the ends of the existing 2x8x8'0" header now supported by a center post. Secure a lam-micro beam to the face of the header from the bottom of the header to the bottom of the joists. Secure a vertical 2x6 to the existing wall on both ends of the 18'0" lam beam for support. Apply 1/4" ply to the 2x6 vertical surface so that it is flush with the laminated beam 1 3/4" thickness.
