confusedcarp
- Joined
- Jun 16, 2021
- Messages
- 41
I want to replace a window and install new doors and siding on my detached workshop. After much research, I've come up with a step by step plan. However, since I've never done anything like this, I'm hoping someone can please take a quick look at my plan and let me know if there's anything I've missed or if the order needs to be tweaked.
- Prep exterior - remove trim, scrape flaking paint
- Remove front door and jam
- Remove window
- Reposition window studs and cut opening to size replacement window
- Install new patio door studs and cut opening to size
- Dry fit replacement window and doors and adjust as necessary
- Patch vent holes with plywood
- Seal bottom of exterior sheathing
- Install drip flashing along bottom of sheathing (needed?)
- Install exterior house wrap
- Tape seams
- Install tape flashing around window and door openings
- Install window
- Install doors
- Install Drip flashing above doors and windows, tape house wrap down over flashing
- Paint and install corner, window, and door trim
- Install soffit, fascia, and roof drip edge (this is a retrofit, doesn't exist yet, might do before or after panel siding depending)
- Install panel siding
- Cover panel seam on gable ends with painted trim
- Caulk nail holes and seams
- Paint
- Install gutters
