Report on my self install mini-split 1.5 years later.
old__man
Gander, Canada
Garage specs:
24X24X14
2X6 24OC
Concrete slab uninsulated
Attic is probably R40-R50. I forget.
Unit is 12K cold weather unit found here
Climate is best describe as so-so cold and quite damp. Found here
Details:
I did the install solo myself. It was relatively straight forward. The only tools I bought were a vacuum pump and the fancy flare tool off Amazon. Better part of a day to install including messing about with electrical. It is attached to the wall using lag bolts and blocking. The unit has worked flawlessly since. Only cleaned it twice due to it being a works space and having an elderly diesel parked in it. I also make sure to turn if off if I am spraying stuff such as paint or under coating. Some noise does transmit inside the garage when it is spooling up but it is barely noticeable.
It was -15C (+5F) overnight, the unit was set to 17C (63F), and it kept it. For fun I commanded it to increase to 20C (68F) from the comfort of my bed (phone app) and it did so in a little less than an hour. Obviously all the metal tools in there will take longer to get to temperature. The unit is not capable of being set lower than 17C but nor would I want to. It stays on all winter long. To note, there is a 'freeze prevention' setting on there that, I believe, tries to keep space at 10C (46F). In the summer I mostly use it in 'dry' mode to get rid of the humidity, cools things nicely as well.
Over all I am ecstatic with the unit. It works much nicer than my professionally installed LG that's in my house, that thing is, or lack of better word, just dumb. I'm glad I didn't got with a 18K or even a 24K as some had suggested. I definitely would recommend a reversible ceiling fan to go along with it.
Given the choice, I would go this exact route again. I hope this helps someone with sizing choice.
These are the best pictures I have.
O
old__man
Gander, Canada
How much time do you spend out there daily?
Some days it's all day and into the evening if I am working on stuff, sometimes it just an hour, and other times I will go days without going into it. I park my truck in there in the winter so it doesn't get covered in ice and snow. Also makes it easier to plow the drive with put my truck in the way.
Nicest thing about the shop being at temp all the time is the tools don't get cold. Nothing ***** more than handling a frozen ratchet.
Phuckin' Jim
North of the Peg
Looks good!
We have the 9k btu version installed in our house in Manitoba.
I have seen it make some heat at -35 C.
We use it mainly in the shoulder seasons.
When it's really cold we use the wood stove.
Very happy with ours!😀
brianh
grahamsville NY
Last fall I installed 2 pioneer 12k mini splits on our house. I put KW and real time watt meters to see how much they add to our usage.
So far very happy with the performance we have had two days at -10F and more subzero nights they still were putting out plenty of heat, at -10 they were running 900 watts each while in the 20's they run 500.
We do have a wood stove it has been our primary heat for the last 28 years we use it now but its not roaring full blast. I will probably be adding one more unit next year.
After I mounted the first one on the house and had some compressor noise the second I mounted on a frame not attached to the house I also put a roof over them it has seemed to reduce icing on freezing rain days.
My wife the one who hates change loves them.
O
old__man
Gander, Canada
Mine has very similar watt numbers as yours. I also have a real time KW meter in the house. As well I have a wood stove in my house in the basement. I only use it on cold night when the heat of the upstairs (18K) heat pump can't easily make it downstairs.
I think you will find the other advantage of heat pumps in the summer. Their ability to not only cool but function in 'dry' mode and dry the air out while slightly cooling it. They sip power doing that and it makes the house so much more livable.
brianh
grahamsville NY
Yes another reason I installed them, we were using two 5000 btu window AC units not having to put them in and lose windows and deal with the noise is a big plus.
