Repurposed Eldredge Vintage (sewing?) table
fishwatcher
I picked this up at a garage sale last weekend. It’s old, the table top is new, but I think this was repurposed from something else.
Looking up “vintage Eldredge” I see it might have been a sewing treadle. Any ideas? I’m keeping it outside and will use it as a handy table/shelf outside my shed and bbq.
It’s a little wobbly. I tried putting a single threaded rod and acorn/locking nuts through it.. but that didn’t do anything. I’d love to make more solid if you have suggestions.
Stuart in MN
Minneapolis
Yes, it's a base for a treadle sewing machine. The foot treadle would have gone where that rod is now. There's a brief history of the company here: https://ismacs.net/national/from_eldredge_to_national_to_janome.html
When I was a kid my folks had a summer lake cabin, and there were a couple tables there built from Singer sewing machine bases. They sat outside for decades with little wear, they are pretty durable.
edit: It looks like there may be another hole just above the Eldridge lettering - if so you could maybe install another crossbar there.
F
fishwatcher
Wow.. looks like this base could easily be over 120 years old. Neat. Thanks @Stuart in MN.
I tightened up the main base nuts which stabilized the whole thing.
I have some Krud Kutter for Rust which I will use on the base and then maybe I’ll paint it before it gets too cold. The teak top could use a coat of sealer.. so I’ll try some boiled linseed oil I just got for another project.
It looks like turning treadles into tables is a thing on YouTube. Not quite as interesting or as popular as restoring vises, but here again is something I’ve learned about from GJ.
nadogail
Coronado, CA
Another tie rod , or Cross Bar, will make your table more rigid; but it will still be a parallelogram.
if the Upper Tie Rod could also be tied to the table surface, your table would be even more rigid.
Jim_No_Garage
Millington NJ
There was probably a wide cross-member joining the vertical sides where you have the small threaded rod. That cross-member mounted the treadle to the sides.
DAMHIKT . . .
Jim
PS: I have the bases, wood for the tops but nowhere to put the finished tables in our admittedly full house . . . LOL
F
fishwatcher
DAMHIKT . . .
Jim
Thanks for sharing your thoughts and pictures. Why do treadles have wheeled bases? Mine look similar to yours. They only roll horizontally.
