Repurposing plastic 55 gallon drums
airrj
Wide Wonderful Wyoming
So when my neighbor was cleaning out so they could move, I received allot of their cast off stuff. One of the items was several 55 gallon plastic drums. Not knowing what I was ever going to do with them I stuck them in the back corner of the shop waiting for a purpose.
First I found out what was originally in the drums and found out that it wasn't methyl-ethyl-death and I was able to safely clean them out with soap and water. I needed a few drums to use a essentially garbage cans. I am specifically using them to hold my plastic recycling. I have to collect my recycling and take it to a center, so I don't put it out to the curb every week like many do.
To cut the top off of the drum I used a cordless 5 1/4" circular saw. After making a line around the drum, using the circular saw made for a fairly straight smooth cut. Next I used a hole saw and a mini hacksaw to cut in some handles which worked out very well for the light weight of these barrels and their contents.
So, now what to do with the cast off top to the barrel?
It looked like it might be useful in the shop, so I tossed it in the corner and there it sat for many months. Then one day, I was installing a water pump on a neighbors Ford tractor. I quickly realized that when I took the pump off of the block there was going to be antifreeze dripping everywhere even though I drained the radiator. No matter where you put your drain pan the coolant always finds a path to miss the pan.
So, I noticed the big blue tub sitting there and it was noticeably larger than the normal drain pans.
So I have now used this pan for a larger diameter pan for messy jobs. I next had to drain 10 gallons of foam out of a fire engine and the manufacture put the drain outlet directly over a cross member again, so it would drip all over the place. And once again, the larger pan was very helpful.
Just another idea for you all to think about.
Thanks for looking.
454ragtop
Carver, MA
I have one with a removable lid I use as an electrolysis tub, put whole V8 engine blocks in it.
Jim
malibu101
Walnutport PA
My neighbor uses 3 of them that he diverts rainwater from his roof into and uses it to water his garden in the summer. I swear rainwater is better than chlorinated city water for plants by the way his garden is always better than mine.
At work we use them for scrap metal containers. They're not too heavy by themselves and they're pretty strong for holding scrap.
kctyphoon
Jersey/Staten Island
i have two of those at work - i cut them in half, drilled a holes on either side of both halves and ran a 4' piece of strand from one hole to the next.. basically turned each half into big buckets. i keep them filled with dirt on the bed of my digger derrick at work, and use them to fill the holes from any telephone poles we remove that arent easily accessible with shovels. i use the boom to lift them over fences or what not.. its pretty amazing how much weight they hold, the plastic has never cracked or torn at the holes even with a few hundered pounds in each one..
NewEdgePerf
There is a local guy that once used plastic barrels attached to the end of the blades on his homemade windmill. It was huge! And it worked!
Not sure if any pics exist of this or not. This was "PI", "pre-internet".
Tony D
Swan
Winona, MN
Blue plastic barrels such as yours are generally food grade containers. I too use them for rain barrels and electrolysis. A local company (Watkins) sells them for $5 each. Many people use them for floats for their docks and houseboats.
Chris Stapley
Campbellford, Ontario
take caution with that thought as well Swan, I used to get all of my bulk battery acid in blue plastic barrels the very same as well when I ran the service department for my local New Holland dealership....
schmelpboy
Well don't you dare put them outside with an open lid and try to steal the government's water!!!!
gungatim
west mich
we use the barrells for 2 purposes: cut in half, cut hand holds in side, one fill with ice and beer for party's, the other half sits under a deer, when you are done skinning it, you cut off the head and gut it, everything falls/drains into the barrell half for clean deer processing. carry it away to dispose of the guts...or you could use it to ferment some corn for making ethanol...
PhantomEB
Medicine Hat, AB, Canuckistan
I pickin up 4 white ones shortly. Harvesting all the rainwater I can. May be a fifth inside the garage for spraying down vehicles or the toys as well camping gear! All mine will be able to have water moved from tank to tank by way of a 12v inline pump.
