Hello all,
I'm new here and have been reading up on most of the lift threads. I plan on getting a 4 post as it will be used more for storage. I believe I will have the garage door clearance worked out as I will have the high lift tracks installed and the ceilings are ~11'. Along with choosing a quality lift, I am also concerned with the other requirements that come with installing lifts.
They seem to be 220V operated with some companies having asterisks on the voltage rating and noting that they can change the voltage operation. I would like to stay with 110V for convenience, but would I have to install a separate circuit anyways? If so, I'd rather just run a 220V outlet. Problem is, my panel is FULL - something that can be worked around, but still.
Also, it seems I'm finding that they are air operated? Meaning you will need a compressor to run certain functions? I would rather not have to use one, but will if it is a must.
Thanks for your replies.
